TwinTurbo.NET: Nissan 300ZX forum - Re: PTU vs Coil Pack Timing
craigz96tt
on November 05, 2012 at 10:45 AM
posted by alpha_omega16
on November 04, 2012 at 09:31 PM
I believe the only sure way to adjust or check timing if you don't have the Nissan adapter is to use a common plug wire with the #1 coil removed then you have to compensate if you have under drive pulleys with a different view angle
alpha_omega16
21:31:46 11/04/12
Commonly known.
Woody75 (Denver)
22:13:49 11/04/12
I will give it a shot tomorrow..
alpha_omega16
22:44:32 11/04/12
Auto ecu is going to show higher timing. 20 I believe. (n/m)
Woody75 (Denver)
09:19:06 11/05/12
Re: PTU vs Coil Pack Timing -
craigz96tt
10:45:05 11/05/12
is your idle switch on? Is your idle speed correct?
aliaZ
17:28:37 11/05/12
Yes, the idle switch is on and functioning correctly.
alpha_omega16
11:33:40 11/06/12
The ECU expects 15 degrees, not 20
aliaZ
23:29:18 11/07/12
Agreed... timing light is the only way!! (n/m)
Medallion Man
10:41:26 11/08/12
